Is it possible to enter Multiple Barcode for single Product/Artikal in Master
ShriFunnzGuy
Hi All
In Sage 100, it is possible to store multiple Barcode against single Product , the problem is frequently changing Barcode therefore we are not able to find product with Barcode.
Thanks in advance
Regards
Shri
Hello,
do you want to use an EAN number as a barcode or are these possibly different order/item numbers for each supplier?
